Gjac
Oct 01, 2014Explorer III
ScottG wrote:All adhesives are weaker in peel than in tension. If the adhesive is epoxy, solvent won't work if it is some kind of contact adhesive acetone would be the best bet to soften the adhesive. I would try to start the peel with a razor after acetone at the bond line then grab with Visegrips to peel it off.
When removing them, pull it straight back against the itself. If you pull it off perpendicular to the surface you have the highest risk of damage.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
