Heavy_Metal_Doc
May 17, 2014Explorer
Happy Prospector wrote:
Yep, Taking a truck to a tire shop for engine work! It appears that you may have been educated beyond your intelligence.
I was kinda thinking along the same lines -- I never take a vehicle for any diagnosis and repair to a shop that has "tire" or "lube" in their name....you go tehre for tires or and oil change (I don't even trust them to do that right - or at least not to use good parts / oil)
Stories like these make think that the general driving public has little idea what really goes on behind the bay doors of most shops, no matter if it's lawnmower repair, heavy equipment, or anything in between.
Lube and tire places, while they may advertise all sorts of other service / repair, are notorious for being the stepping stone shop for a "learning" technician. Most good tech's move on to shops where they can make more money. Sure, they will have one tech who really does know what he's doing, but when the workload is high, you show up and get the oil-change monkey trying to diagnose a missfire.....
I rarely use the services of a shop since I can do 99% of my own work and the rest is deep diagnostics requiring the really expensive tools. I don't need that often enough to spend the money for more than basic code reader and pressure tester.
This is one area of RV'n that makes me cringe -- a problem on the road and ending up getting hosed due to not knowing if the shop is good or not.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
