murlsketeer's avatar
murlsketeer
Replace Hot Water Tank Propane Gas Valve
I need to replace the hot water tank gas valve on my travel trailer. I have been doing a lot of searching and found the Suburban 161109 Gas Valve for $40. I then found the Dometic Atwood Mobile Products 93844 for $125. The only difference is that the Suburban is 10.5" reg and the Dometic is 10.0" reg. The valve on the TT has a 10.0" reg. My question is what does the 10.0" and .5" reg mean? Can I change out the the valve for the Suburban without causing damage to the water heater? I really don't want to spend three times the amount if I can use the 10.5" reg. Thank you for any advice that you can offer up.
  • What is the exact make and model of your water heater?
    Even slight differences can effect the burner.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
