Sam_Spade
Aug 17, 2019Explorer
garym114 wrote:
Charging requirements are not the same for AGM and wet cell batteries.
While that is true, AGMs will perform quite adequately using the settings for a conventional wet cell and most people won't notice the difference.
You mentioned having to top up the batteries often.
If that was indeed true, you really NEED to check the charging voltage coming from your converter/charger, especially after the batteries are fully charged. Your charger might be defective.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
