Bumpyroad
Feb 14, 2017Explorer
ctilsie242 wrote:
There is a bump on the outside of the key, about 1-1.5 millimeters, when the lock is at the 12:00 position. File that off, and you can pull the key out at any stop.
I found some double-sided locks that have a shutter... same lock mechanism as gas caps, so I decided to use those. The key is thicker, so it won't snap in my hand like the CH751s do.
you are talking about that little Nubbins that you have to line up with the slot to insert the key? without it, just poke and guess, or guess and poke.
bumpy
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
