pompomgirl's avatar
pompomgirl
Replacement Locks for Under-Coach Storage Compartments
Later this year, we will full-timing in an urban RV park and by necessity will have our under-coach storage compartment full of needed items, some relatively expensive. I have been looking into more secure locks for those compartment doors and have found that, as I suspected, they are all the same, with only a few different keys.
Is there any way to make those compartments more secure? Some different type of lock? Obviously having the existing ones re-keyed is not the answer.
Thanks.
  • I replaced my 751s with those with round keys. yes, I know years back, bic pen, yadda, yadda, yadda.
    bumpy
  • The best of locks will not stop someone from prying doors open. Even the best doors and locks are no match for a knucklehead.
  • If yours are the commonly used cam-type locks and it's the common-key thing that worries you, those can be had as "combination locks". You choose/change the combination at will.
    Cost about twenty bucks a door if you add in the separately sold finger-pull.
    Link to source.
  • I will assume, thou you did not mention, that this is for your 2008 Coachman Freelander 2600.
