PNW_Steve wrote:
I would go with a standard mattress but in order to get the mattress into the bedroom I have to fold it in half.
With the gel memory foam, it comes rolled into a "jelly role" in a box that is about 10" X 10" X however wide the mattress is. If you take the entire box into the RV, then open the box, quickly sling the mattress onto the bed platform and THEN cut the plastic off, it's a breeze to get in. If you make the mistake of taking it out of the box, the plastic will leak just enough air to make it a pill to lug around. If you take the plastic wrapping off, it makes it nearly impossible to get the booger up on the platform. Ask me how I know that!!
