cmarkj's avatar
cmarkj
Replacement WDH shaft
Gathering info in case I need it in a month or two. Just upgraded our TV to a 3/4 ton. Of course, that increased the receiver size to a 2 1/2” from a 2”. I think it may also be higher enough that I might need a different shaft because I may not be able to drop the ball enough on my existing one. Packed away right now so I can’t be sure, but I’d like the info in advance so if I need one, I can get it quickly.
Two questions: do I get a 2 1/2” if I can for my style of hitch and where do I get one?
I have a preo-series round bar with 1200/12000# set up.
Thanks
  • You're looking for a shank, not shaft. Blue Ox makes a 2.5" drop shank that should work well for your application. BXW4028
    CURT 17132 is an option, though it's so much cheaper I have to question the quality.
    Reese 54977 is the other option I've seen, but it's only for pretty significant drops so not as flexible as the blue ox.
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
