catkins's avatar
catkins
Explorer III
Mar 21, 2018
Replacing 2006 Vue - Equinox or Edge
Sadly our 2006 Vue is getting a bit tired and worn out. Time to replace it.
Anyone towing a Chevy Equinox or Ford Edge and would you recommend it or not? Thanks for any info we may lack. Both seem to fit our bill but want to hear from owners. THANKS
  • Heisenberg wrote:
    Our 2012 is a wonderful vehicle whether we tow it or not. It is the 4 cylinder and we have never experienced the steering ghost.
    2012 What?
  • We had two Edges as toads. Very good for us. We had charging line added.
  • lryrob9301 wrote:
    jplante4 wrote:
    Some say a bungee cord on the steering wheel fixes the problem, but I don't understand how. Electric steering on the 4 cylinder models has no hard connection between the steering wheel and the front wheels.
    This is incorrect. The Equinox like all vehicles has a steering shaft that runs from the steering wheel to the rack & pinion unit which is then connected to the front wheels.
    Thanks for clarifying that Larry.
  • Our 2012 is a wonderful vehicle whether we tow it or not. It is the 4 cylinder and we have never experienced the steering ghost.
  • We have a 2008 Ford Edge that we have been towing for nine years with no issues. On the older models like ours there is no special prep needed, just put in neutral, release the parking brake and turn the ignition key all the way to the left. We like the Edge so much that we also bought a 2013 for our daily driver.
    This is incorrect. The Equinox like all vehicles has a steering shaft that runs from the steering wheel to the rack & pinion unit which is then connected to the front wheels. It doesn't matter if it is electric ASSIST or hydraulic ASSIST. The reason the 4 cylinder models exhibit bump steer (correct engineering term) is when the electric assist is not powered it does not provide dampening to the steering to prevent overcorrection. 6 cylinder models have hydraulic assist to the steering and provide constant dampening force to prevent overcorrection (bump steer) all the time, key on or not. Thus a bungee cord through the steering wheel provides a constant centering force on the steering helping dampen bump steer forces on 4 cylinder models.
  • Edge is my daily driver for over a year now. The wife and I both love it.
  • I just set up my Equinox for towing. I haven't towed it yet.
    Do a search on the death wobble issue with Equinox. Chevy has changed their fuse pulling recommendation from fuse #32 to some other fuse (#16 I think) to leave the electric steering active with the key on.
    After studying up, I got a used 2014 Equinox and wired the coach to supply 12 volts to the toad. I won't be pulling any fuses.
    BTW, the Equinox, GMC Terrain and Buick Envision are basically the same car.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
