wargle70's avatar
wargle70
Replacing foam mattress with air mattress on a hide a bed
I have a 2006 Montana Mountaineer that has a hide a bed with a paper thin foam mattress. The tag on the mattress says Flair Industries, so I assume the sofa bed is also made by Flair. The mattress frame measures 53'X72". I would like to replace the flat foam mattress with an air bed type mattress, but am wondering if; 1. I can find an air mattress that will fit and, 2. will it fold up correctly. The bed folds up with part up behind the back cushions and the rest under the seat cushions of the sofa. Any information would be helpful. Thanks.
  • We have use airdream mattress for past 4 years. Works great.
  • Look at Airdream mattresses as sdianel suggested, we or should I say our guest seem to get a comfortable night sleep on it.
    sdianel wrote:
    Cons: You may have to replace the bladder every 2 years. We finally gave up and got a 4" memory foam mattress for ours.
    Ours has the original bladder with no issues for the past six years.
    https://www.airdream.net/
  • Two issues:
    - As mentioned, it supports the seats when closed.
    - When an inflatable mattress is folded up will metal parts chaffe and quickly put a hole in it (even if deflated before closing.
    We've put an inflatable matress on top once opened and that works OK, though you are a bit high off the ground.
  • The foam mattress may be necessary for proper support of the couch in seating position. Remove it and the couch might not have proper support
    . Why not go to the closest sporting goods store and pick up a Coleman inflatable mattress. Put it under the the foamy one when in bed position. Should be real comfy that way.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
