Gdetrailer
Apr 19, 2017Explorer III
DrewE wrote:
On most non-opening RV windows, at least the ones I've seen, the glass is held in not with the rubber molding (which is mainly for appearance, though it probably does add some strength) but with an adhesive sealant between the glass and the metal frame towards the inside of the glass pane. I wouldn't attempt to remove it unnecessarily.
Travel trailer glass is not required to be tempered/safety glass, so far as I know, since people wouldn't be in the trailer while driving down the road. It may very well still be tempered, though. Windows in passenger vehicles including motorhomes must be some sort of safety glass, either tempered or unlaminated with a safety film or laminated with a safety film.
If this is a side window, how will you deal with the air conditioner sticking out while driving?
:R
I have been down this argument road before..
YES, "tempered" glass IS "required" in travel trailer windows, it is now days called "safety glazing". I would rather have billions of smaller rounded glass pieces flying at me or other motorists if the trailer was involved in a wreck on the road..
If you do not believe me, go take a hard look at YOUR trailer windows.. You should find a small triangle watermark in one of the four corners of the glass which will state either tempered or safety glazing.
I know ALL of the windows in my 1984 TT HAVE the tempered marking as well as my previous 1981 TT..
The tempering process is a GOOD THING, not a bad thing. Tempering strengthens the glass and the process creates a surface tension on both sides of the glass which when broken, makes the glass break into millions a less sharp pieces unlike untempered plate glass where you often get huge jagged shards..
