Bumpyroad
Apr 20, 2017Explorer
Guy Roan wrote:Bumpyroad wrote:qtla9111 wrote:Bumpyroad wrote:qtla9111 wrote:
In my last travel trailer I used corrugated plastic for the cut out. I built a shelf that hung on the emergency window ledge with an angular support underneath.
that would make an exciting exit in case of a fire emergency .
bumpy
I'll overlook you always smart remarks.
Seeing that it is an emergency window, you just push and everthing would fall to the outside.
Keep racking up posts my friend, you'll comment on anything.
so you don't think that one needs to construct this with the idea that it might need to be kicked/pushed/etc. out in case of an emergency. that is not a "smart" remark.
bumpy
It was obvious to me that you wrote it as sarcasm, so I ignored it since I was looking for someone who had done it.
If you can't add anything helpful you might want to refrain from posting.
Guy
so you don't think that reminding somebody of a potential issue is helpful. if not you are not very helpful and could refrain yourself.
bumpy
