Paul1944's avatar
Paul1944
Replacing House Batteries.
I need to replace my house batteries in my 2004 Coachmen Sportscoach. I currently have four 6 volt deep cycle golf cart batteries installed, two 6 volts hooked in series to create 12 volts then the two 12 volts pairs hooked in parallel. I'm thinking I would like to install the optima maintenance-free batteries but I can't figure out which battery I need to order or how many I need. Any help will be greatly appreciated. Thanks.
  • he wants to replace all (4)
    he just picked the wrong battery, and is asking advice
    the Optima 6 pack spiral wound are very rugged
    if you have a JET SKI, or bouncing a desert buggy over rocks
    but the constructions means the Optima weighs less, and has less 'LEAD', and less ampHrs useable capacity
    for RV dry camping you want Maximum capacity per battery size
    there are many other 'sealed' AGM batteries that will better serve your purpose other than Optima
  • midnightsadie wrote:
    you should NOT mix batteries old and new ,change them all.
    Yes, but that's not what he's doing.
  • Paul1944 wrote:
    Because they are maintenance-free, am I showing my ignorance here? Maybe there are other maintenance-free batteries that I don't know about.
    Yes.
    ANY AGM battery is essentially maintenance free (sealed).
    A "deep cycle" AGM weighs a TON and costs a lot too.
    But that's what I got last year.
    When you have an "old" RV, it seems like SOMETHING goes bad every year. I don't want to have to worry about the batteries for a while.
    P.S. Are you sure that you really NEED that much capacity ??
  • 2oldman wrote:
    Why those?
    Why those?
  • Forget optima, those spiral wound batteries have less capacity
    Four of those will give you about half of the capacity in ampHrs that you have now
    Get good quality AGM batteries like full river ?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
