buzzard616 wrote:
Signature TV has had load range 'E' tires on it for the last five or six years and even with 8200 lb TT on the hook I never liked the ride at the 80 / 65 PSI pressures the TPMS wants. Last season I ingnored the annoying little light and ran 65 / 50 PSI with no bad handling habits or tire wear and a considerably nicer ride.
Now that I need new rubber I am thinking I might as well switch to load range 'D' tires.
Any thoughts from anybody who has actually done this?
Stu
If you were running around at 80/65 w/o towing then right there is your problem. Those pressures are WAY TOO HIGH for the non towing configuration and your 65/50 is much closer to what is needed for non towing. Unfortunately your TPMS is non adjustable and is based on the max load as per the FMVSS door jam label.
Larry
