reasley
Feb 26, 2015Explorer
I had to go back and look it up. Suzuki started putting in throttle body injection in 90.
You can put a wide variety of engines in the samurai, but the most popular and easiest is the 1.6. It comes in an 8 valve or a 16 valve version. The 8 valve with throttle body FI is easiest by far. The 16 valve is multi-port and far more complex. I think all of the various conversion engines are taller than stock and cause some fit issues. In my case it's a 1.6, 8 valve and I wanted to keep it spring under axle so I had to do a 2" body lift to clear the engine. Many just go to spring over to get the clearance.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
