Executive45
Apr 06, 2015Explorer III
Most likely, you're putting in too much information. When I simply put in "looking for an RV site" with no options, it gives Sanchris as the first option. If I put in options such as size, hookups, ada, sewer and pets it changes. As you change your parameters the locations also change. Try a search without any options selected and see if it corrects itself.
I logged into my account to see if there was a "sort" box and there is none, so I can only assume it has to do with the parameters you're feeding into the site....Dennis
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
