Sandia_Man
Apr 21, 2022Explorer II
It sounds like you just need to power fridge from home to campsite or to the next campsite, might be doable for a single group 27 (not the best battery for this scenario) although you will arrive with a pretty depleted battery, a 2nd battery would certainly help. You could travel with fridge off for a few hours, we've done so and had no issues as ice cubes and ice cream are still frozen upon arrival.
I did not try to read too much into your OP as there is no mention of extended or overnight use, which obviously would require a rather large investment in solar and batteries, and still would require usage of a genny and a fast charging converter or inverter charger when solar can't keep up. We do lots of RVing under adverse weather conditions and would not do so without a genny onboard.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
