wa8yxm
Apr 22, 2022Explorer III
austinjenna wrote:
I know there are variables involved here on the manufacturer of the fridge, battery etc... But for those of you that have one assuming the standard group 27 battery the dealer gives you - how long can you run that fridge on just the battery?
Group 27 = about 100 AH, Marine Deep cycle you should not use more than 25 Ah. that's translates (Once you run it through an inverter) to about 250 watt hours (1/4 KWH) note this is at the 20 hour rate. used at the higher rate of the fridge. 1-2 hours run time likely 1.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
