willald
Apr 29, 2022Explorer II
goducks10 wrote:
I would suggest upgrading your charger to a Progressive Dynamics that has the option to bulk charge anytime. Even if your batteries drop down 30-40% a standard WFCO won't bulk at more than 13.6-8. You waste a lot of time trying to quick charge at 13.6.
Not sure who this was directed to, but in my case, putting in a PD converter would be not only a huge down grade and not very smart, it would also be nearly impossible without redoing much of the electrical system.
Our RV has the Xantrex Freedom XC 2000 Inverter/charger unit. It provides really, really good multi-stage battery charging; Every bit as good if not better than what any PD converter would provide.
Although I do agree that for a lot of RVs, a Progressive Dynamics converter with multi-stage charging is a great upgrade over what it comes with from the factory. I did that upgrade on a previous RV we used to own.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
