StirCrazy
Apr 30, 2022Moderator
willald wrote:goducks10 wrote:
I would suggest upgrading your charger to a Progressive Dynamics that has the option to bulk charge anytime. Even if your batteries drop down 30-40% a standard WFCO won't bulk at more than 13.6-8. You waste a lot of time trying to quick charge at 13.6.
Not sure who this was directed to, but in my case, putting in a PD converter would be not only a huge down grade and not very smart, it would also be nearly impossible without redoing much of the electrical system.
Our RV has the Xantrex Freedom XC 2000 Inverter/charger unit.
not sure I would agree with you on that one. Xantrex is a upgrade from WFCO, but I wouldnt say a upgrad over PD. but since you chose to go with a inverter/charger all on one unit I wouldnt change if I were you either. PD would be a quality upgrade on the actual parts but like you said not worth it in your case.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
