- westendExplorer
smkettner wrote:
+2 :B
+1 for batteries and solar :B - bmuptonExplorer
bob_nestor wrote:
mlts22 wrote:
My dream:
Residential refrigerator + decent PSW inverter + decent battery bank + this.
Functionally identical to an absorption refrigerator except that the fuel cell keeps the house jars topped off, my beer gets cold fast, and I don't have to perfectly level my rig.
The specs say that fuel cell consumes 100 g/h which I assume is gallons per hour! I hope that's a misprint or your dream RV is a tanker truck.
I'm guessing g is 'grams' not 'gallons' since gasses of this nature are usually measured by weight, not volume. - bob_nestorExplorer III
mlts22 wrote:
My dream:
The specs say that fuel cell consumes 100 g/h which I assume is gallons per hour! I hope that's a misprint or your dream RV is a tanker truck. - malibuskierExplorerJust be smart about which refrigerator you pick. I have a Samsung that only pulls 5 amps (26cf French door model). Compared to other brands that pull 10 - 12 amps. They add up quick....
- dkreuzenExplorerI have a 2012 Monaco Knight 36PFT Diesel Pusher which should be identical to the OP's 2013. It has a 2800 watt Magnum inverter and 3 stage charger, 4 L16 6v batteries (about twice the size of a normal 6v), and generator auto-start.
The refrigerator will run off the batteries for about 24 hours depending on how hot it is and other loads. I have dry camped once for 4 days, and it was hot (100 degrees). With our normal running of the generator for an hour or so in the morning and evening to cook meals we had no issues keeping the batteries charged and the refrigerator running. - harold1946ExplorerIf not allready equiped with one, I would add an AGS (automatic generator start).
- John___AngelaExplorer
MrWizard wrote:
2013 Monaco Knight 36PFT Diesel Pusher
you have plenty of generator about 7~10kw quiet diesel
i'll guess on the inverter setup and say (2) 2000w victron's in a paired setup
6 maybe 8 batteries
all you have to do is remember to run the generator during the appropriate hours so your batteries stay charged up
if you need A/C you need to run the generator
Hmmm, although all valid I think his unit is already equipted with the inverter needed to run the fridge which is I assume factory. I'm guessing that they are not using victrons and it is probably a Xantrex or magnum 2000. More than adequate for all coach needs. Victrons are nice products though. - MrWizardModerator
6 maybe 8 batteries
if you need A/C you need to run the generator - +1 for batteries and solar :B
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Oct 01, 2015
