rsaylor3's avatar
rsaylor3
Ridge Grapplers PSI? I have a bit of wiggle now
So I had put 285/75/17 Nitto Ridge Grapplers on my Chevy 2015 2500 HD stock wheels. Nitto said to run 65 psi in the rear and 47 in the front. This would give me the same carrying capacity as the stock Michelins at 60 and 75 like the door sticker says. They carry the same weight at 65 as the Michelins did at 75. I actually keep them lower when not towing, both front and rear.
So I towed my 9,000 travel trailer for the first time since installing the Grapplers and noticed more movement in the trailer than normal. Before it was pretty well locked down with the Blue Ox Sway Pro and 1,500 lb bars. Been using this setup, same truck and trailer for 3 years. Not sway to scare me, but just needed a lot more steering correction for passing trucks and a windy day. My tongue weight is right at 13%. I was wondering if putting the tires to 80 psi was too much and I wasn't getting a full width of tread patch on the ground? Could this have been the case and why I felt that difference in tow? I have over 6,000 miles on the new tires, so I think they are worn in enough. I always ran the Michelins at 80 when towing so I did the same here, but am second guessing myself now. Heck, I think maybe I need to run the fronts lower as they suggested as well.
Appreciate your thoughts?
  • Considering the off-road type tread for those tires, it's very possible you're just experiencing tread squirm. Those might be the wrong type of tire for towing a heavy trailer.
  • no, they are load range E. Was hoping someone one here had experience with tire pressure on tires with higher load capacity at lower psi. I'm going to do some rest runs and adjust pressures down to see how it goes.
  • What LOAD range are they??? If they are "D" take them back and get "E".
    Lots of places like LesSchwab are famous for selling a lesser load range tire but telling people that the carrying capacity is the same.
  • New tires tend to be a bit squirrelly until they are broken in after a few miles. Your problem though is probably due to the taller sidewalls. Higher psi may help a bit but won't solve your problem.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
