Paul1944's avatar
Paul1944
Risk of down-shifting?
I have a 2004 Coachmen Sportscoach with a 330hp CAT, and 6-speed Allison transmission. Here is my question. Do I risk damaging my transmission if I down-shift in order to slowdown or to save on my brakes when going down a long and/or steep grade? In reading through all my manuals I cannot determine if my coach is equipped with a jake brake.
  • Most transmissions will protect themselves, so you'll need to use both brakes and transmission. Get RPMs down to the lowest gear that will allow control, then use brakes to help drop RPMs. Don't ride the brakes (or do your best not to). Work your way down until you get to your desirable speed. Use lower gears as much as possible.
  • The Allison transmissions I am familiar with will not allow you to downshift if the RPMS are too high. It has it's own computer to prevent damage.
    If you try to downshift at too high RPms the tranny will not shift.
Looking for advice before your next adventure? Look no further.25,157 PostsLatest Activity: Aug 13, 2025
