D_E_Bishop
Jun 28, 2014Explorer
larry barnhart wrote:Larry you say you removed the RMP, what did you use? I have tried using the ZEP RMP Stripper in the Blue jug and it takes forever and never seems to really remove everything.
I wonder if you really did a good enough job for the prep work if the rv had been waxed. Now after saying this I also had flaking but 3 years later. I removed the RMP and applied poli glo. Same look as the RMP but a lot more money. Waxing 2 to 3 times each year was never easy as you understand getting older. Same here. I finally learned the best method for me to remove the RMP after removing it from the side that really flaked off during the winter.
chevman
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
