John_S2's avatar
John_S2
Rodents (mice) keep infesting trailer and pickup truck ???
What can I do to keep the vermin from invading our trailer, battery compartment and under the pickup truck hood, etc... They keep getting in and setting up nests and chewing things, etc....
Tried some Irish Spring soap but not really solving our problems.
We keep the trailer and pickup truck stored on our country lot for months at a time so the critters seem to like the fact that they are undisturbed.
Any magic solutions to keep them away? Devices, Lights, etc???
Thanks,,
  • Mice want a few things. A dry area and close access to a food source and a tiny bit of water.
    Old fashioned moth balls will work, but you won't like the smell.
  • I put dcon under the hood of Subaru it seemed to work haven't found anymore nest in the heater vents.
  • You can try spraying a product called Mouse Oust (available online) on the ground outside of the trailer/truck. We have had limited success with it but my MIL swears by it. It has a fairly pleasant mint smell. Other than seal EVERY and I mean EVERY hole, no matter how small. We just had to scrap our house fridge because one crawled up inside the back where we couldn't reach and died.
  • I'd try to make sure to fix any places they have been getting into to trailer. Then placing the large plastic outdoor rodent bait boxes under the truck and trailer. If they can feed outside before trying to get in the trailer they should die outside and not inside stinking up the trailer. Make sure not to store any food inside the trailer and wipe down and clean the microwave, stove, stove hood (including the filter if it has one), counter tops, sinks and cabinets where food has left any residue between uses.
  • check with local feral cat rescue/control
    some groups catch them spayd them then turn them loose
    a couple of spayd feral cats will get the rodents
    with out breeding a population that will get out of control
  • You need to find and seal every and I mean EVERY hole. SS screen followed by spray foam. Great Stuff has one that is listed as rhodent proof. Does a great job of stopping them.
  • If you can't be there to manage a bunch of peanut butter baited traps then give them Dcon while you are gone.
  • In the area of Chicago there's a big problem with rodent control. Daughter, son in law, and grand sons live in Chicago and had all the wiring on their Toyota replaced twice due to rodent damage. Dealer said Toyota uses soybean spraying on the wiring for some purpose.. A bounty or some birt control is necessary to thin the heard.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
