jondoexxxx
May 28, 2015Explorer
First off thanks for all the advice. I am thinking I will continue with the heat gun to remove the bulk of the calk and roofing material, then use a grinder / sander to remove the remaining pieces.
Then I will attempt to remove additional caulking left on the roof with mineral spirits and then acetone.
If there are areas where I cannot fully remove old caulking, would you all recommend priming and then using eternabond, then covering with the Hengs roof coat?
Should I use the bead of Dicor or other sealant before the Eternabond / primer or just go straight to the primer and eternabond?
Also, here is a pic of the RV, with me on the roof (where I will undobutedly be for the next few weekends ;) .
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
