- Community Alumni
roaminaround wrote:
Thanks guys. Just installed 3 maxair vent covers.
You won't regret it. :C - VeebyesExplorer IIClose them. One of my pet RV grumbles. Cheap & nasty hatches. Might consider replacement with Bomar marine hatches if major surgery is not involved. Not likely to be so lucky.
- roaminaroundExplorerThanks guys. Just installed 3 maxair vent covers.
- BobboExplorer III
RAS43 wrote:
Bobbo wrote:
I prefer the Aero-Flo vent covers to the Maxxair covers.
But I concur, vent covers of one kind or another is the answer.
Had a Camco cover for 2 seasons. Then one spring, after a normal snow season, I found it all broken in pieces. Last one I bought which is too bad as I liked how easy it was to open to clean the OE cover.
I'm running on my ninth year with 3 of them and no problems. YMMV.
Of course, Maxxair makes a copy of the Aero-Flo. It is called the Maxxair II. - Community Alumni
3oaks wrote:
roaminaround wrote:
Short answer: No.
Thanks. I figured vent covers would work but do you get the same air flow from them?
The vent lids will not open as far as they do without the vent covers installed. You may not notice the difference with the fan running, but you will notice a decrease in ventilation without the fans turned on.
Never have noticed any restriction in air flow with our vent covers. And I don't usually run the fan(s) as I don't care for the increased noise. Could be the design of the vent covers, side openings improve the flow over just the rear opening design. - 3oaksExplorer
roaminaround wrote:
Short answer: No.
The vent lids will not open as far as they do without the vent covers installed. You may not notice the difference with the fan running, but you will notice a decrease in ventilation without the fans turned on. - TurnThePageExplorerA few years ago, the vent in the bathroom simply rotted and fell apart while the trailer was stored outside for the winter. It could have been a disaster if I hadn't previously installed a vent cover.
- deweysmith5ExplorerDid anybody recommend vent covers?
- DakzukiExplorer II
Nutinelse2do wrote:
Yes, they do reduce the air flow a bit, but not enough to make a big difference. Get the Maxx Air II's. The advantages outweigh the disadvantages of having the covers.
They also enable the vents to be used with a roof full of snow and wide open when raining. - toedtoesExplorer III
rhagfo wrote:
toedtoes wrote:
I have the cheap camco covers and don't notice any difference in air flow versus no cover. I haven't closed my vents since I installed the covers.
I would like to say that also, BUT we winter camp, and sometimes with the vent open you get a cold draft, especially if you have a fan going in one of the others.:S
I haven't had that problem, but I don't have a real "controlled" temp thing going in the clipper so it could be happening.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
