MrWizard
Jan 12, 2018Moderator
i've been to "Q" three times and never had to worry about freezing
but if your going to Grand canyon / flagstaff, anyplace with altitude
i suggest you bite the bullet, use the LP run the furnace, and keep the Fiver warm
don't let the dog dish freeze and your tanks and pipes should be OK
there should be some heat ducts and warm air circulation into those areas
as long as you "use the furnace" and keep the interior in the 50's or warmer
you can do for this trip, don't play Eskimo and you should be OK
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
