coolmom42
Jan 12, 2018Explorer II
Be sure to have enough battery to get you through the night with the furnace running. It just needs to blow enough air into the underbelly to keep things from freezing. Leave cabinet doors open so the plumbing underneath them gets some warm air circulation.
Don't make the mistake of using electric heaters to the extent that your furnace won't come on. The electric heat won't do the underbelly any good.
If you have water hookups, only use your hose to fill the tank and don't leave it connected. Disconnect and drain it well after every use.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
