- boondockdadExplorerrotating tires on a trailer will only mask potential alignment, loading, hub, etc.. problems.
If your equipment is spec, and you're properly loading, the trailer tires will wear evenly all around.
more than likely, they'll age out, before they wear out. - JIMNLINExplorer IIII've had one TT and three 5ers and many GN/pintle and bumper pull along with two enclosed trailers with single and tandem and triaxle and one tandem dualy axle trailer and never rotated tires on any of them.
- fj12ryderExplorer IIIThe only rotation our toyhauler's tires get is when they are rolling down the road. :)
- Old-BiscuitExplorer IIITrailer tires.....don't rotate but I do have them balanced
Truck..rotate & balance every 10,000 miles - coolbreeze01ExplorerCars and trucks yes, trailers no.
- crickeydogExplorerYep!
Happy camping!!! See y'all down the road!!!:) - BedlamModeratorOn our tandems the rear axle always wears the tires faster due to the axle always swinging through a turn and pivoting on the front. Typically I rotate the tires front to back when repacking the hubs.
- Wheel_EstateExploreron my trailers ( when i had one) i never wore out a set before they AGED out... so i never rotated. I don't usually rotate on my coach either ....for the same reason. of course i rotate on the jeep (and did on the truck when we had the trailer). Now , of course i have rotated them if i was pulling tires for any other reason. or if there are signs of really unusal wear ...i rotated and sought out the reason for the wear.
- downtheroadExplorerTruck - yes.
Trailer - no. - Francesca_KnowlExplorerWe rotate the tires on all our rigs including the trailers...thought everyone did!
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 25, 2025
