Tyler0215
Aug 24, 2015Explorer
Also check your tire pressure, front, rear, and TT. If you are not near to the weight limit of the tires you don't need maximum pressure. Try lowering the pressure 5 psi. It will make a difference in the ride.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
