JRscooby
Oct 30, 2023Explorer II
I didn't look but freezing can be issue in most of the country.
Now I'm not a plumber, but have installed a few frost-proof hydrants, and replaced some where people did not use them right.
If I'm reading the OP right, this is a near-perfect case of attempted murder of the hydrant.
The hydrant is designed to be set with the stem in a bed of gravel below frost line. The actual valve is down at bottom of stem. When you shut the water off, the valve stops flow from pipe and opens the upright so it can drain. A hose, or the add-on line is likely to keep the stem of hydrant full of water. Freeze swell and bust.
You say you plan to bury line hydrant to camper, so much of the digging is in the plan. Why not do it right, tee off the line at base of hydrant, and install a 2nd hydrant near the camper? Then if you disconnect the hose when temps drop, all issues will be in camper.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
