Thermoguy
Nov 07, 2023Explorer II
I ran a sprinkler system in my barn using 3/4" flex tubing, designed for sprinklers. I did some research before I started and Pex is not supposed to be exposed to sunlight or installed outdoors. It is for in walls. I do not recall if it can be buried, but when I compared pricing, flexible sprinkler tubing was cheaper than Pex. I ran about 300' of line with 5 sprinkler heads and it is working great, easy to drain. But, for this application, the frost free hydrant type is the perfect solution. Bury the pipe below the frost line and add a hydrant at the end, use it forever. I have 3 of those around my property including one where we park the RV. Never an issue for getting water to fill before a trip or if a friend is staying for a few days.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
