mr_andyj
May 11, 2021Explorer
No problem except in #3 just aim the exhaust out, not in.
Even your truck burns some of its exhaust again, it is called Exhaust Gas Recirculation, there is an EGR valve to take some exhaust and re-burn it, so no, this is not going to be a deal breaker....
CO is heavier than air, so will find its way to the ground, not so much your windows, which will likely be closed bc you are running your AC anyway. Campers are not airtight, so always a CO monitor is in order.
The farther your gen is from the camper the better.
IF the exhaust is literally blowing onto the camper then you might die, literally, so deflect it or aim it away.
I can't imagine the sound a cheapo construction generator will make in the metal cavity of a truck though.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
