wa8yxm
Nov 28, 2015Explorer III
REgular antifreeze is toxic, a small amount can kill you.
RV antifreeze is a mild poisonm, a very LARGE amnount can kill you
Also Regular antifreeze is what 10-12, more dollars a gallon
RV antifreeze 2-3 dollars a gallon
You will need to completly flush all the Toxic stuff out of your fresh water system. I would do it NOT before it has a chance to "Soak in" if it does that,, Lots of fresh water rinses,m then finally blow the lines out with compressed air, and do not PUT anything in the tanks or lines (Fresh system only) use the Pink Stuff for the waste system (Toilets, Drain traps and such.
on the fresh tank make sure you get it ALL OUT,, ENgine Antifreeze is very nasty stuff.. So make sure you suck that tank dry,, which is not possible on my rig without a whole lot of effort.
I would flush at least 10 times.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
