Kfry's avatar
Kfry
Rv Ceiling vinyl /fabric bubble
Good Day everyone
Has anyone tried to inject or Iron a ceiling bubble on a rv before and if so what product did you use or suggest to use . Any ideas would be greatful , I just have a dry bubble in the ceiling of the cupboard . I re caulked the roof out side just incase it was water . But it was dry and hard still . Just the vinyl bubbled a bit or whatever that material is on those panels .
Awesome any suggestions are much appreciated thank you again everyone .
  • Please see your 'Private Messages' (PM). Pending re-opening and moving your threads. Thanks.
  • I have a 2002 jayco eagle 5th hope that helps guys that k you again
  • If its the old white/cream perforated padded ceiling used by Winnebago for one the glue is starting to release from foam backing. If you have an older coach you can expect more bubbles to start showing up and spreading. Hopefully you have a newer RV and won't face this problem.
  • We picked this up from Lowes.
    glue
    If I remember correctly we used Q tips to apply the glue.
  • Yes it's a white ceiling but hidden in a closet . What type of glue did you use . And thank you very much for your input
  • Not the ceiling, but we had some small bubbles on the walls of our last TT. The vinyl covering over the luan type wall had bubbled up. We cut the bubble with a sharp utility knife so it would lay flat, then glued it back down. There was a pattern so it became " invisible ".
    This may or may not help you. You may be dealing with a white ceiling which would make the repair more difficult. Good luck
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
