Rowehowe's avatar
Rowehowe
RV Door Won’t Open When Sunny
My 1986 PACE Arrow has this problem, seems to be getting worrse, where when its hot out (especially sun baking on the door), then the door won’t open. The only thing, up until today; that would fix it is putting a sharp durable pointy metal poker into the door latch from the outside and prying it open. I have damaged the door and screen over the last few times this has happened.
Before I foundout it was easiest to pry with a pin, it took my 5 hours of unscrewing everything and banging the hinges with a hammer (ruining the aligned connection between the screen door and the regular door). Well the pin I usually use just snapped... I have had a lot of RV problems, probably hundreds, but this one in particular has no solutions I can find online and is always the differential between if I can leave the RV locked or not aka I’m forced to chill in the hot RV till I figure it out. . I am currenrly going in through the driver door, and it sucks. Its uncomfortably hot out in Carlsbad today, as well. Any tips appreciated. -Austin
  • If you have expanding wood products due to water then you have much larger issues than a stuck door.
  • I got it open with a little more force, I am getting to the bottom of this. From what I have read online (for regular house doors), there is expanding water in the foam/wood surrounding and inside the door, and when it heats up the door (or surrounding walls, not sure) literally expands. It was to do with the latch mechanism, but for most people that means a peg or bolt has broken, and for me I believe its just because the door is expanded. Thank you for the replies!
    -Austin
  • Moved from Forum Posting Help and Support
  • There’s no “shinny” spot on the door or frame showing where it’s hanging up? Once open, closing it slowly doesn’t indicate to you where the problem is? From the outside and from the inside?
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
