Some of the white hoses are 1/2" and some are 5/8". Any reason to choose one over the other? Actually, I had never even noticed the difference till I was shopping for one earlier.
Also most of the time the 1/2 inch hose is a bit cheaper. That makes the decision for many folks.
As a full timer, we use 5/8 hoses with heavy duty reinforced fittings. The constant use and with 50+ tear down / setups per year the cheap hoses don’t last. Ive has several fail at this he joint between the screw fitting and the unmoving part attached to the hose.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
