sscheitel's avatar
sscheitel
RV Heat Furnace Cycles on three times and shuts off..
My heat in my 2018 Jayco JF 32BHDS with Atwood furnace turns on:
- blower come on
- cycles to fire up
- warm air comes out of the registers
- air turns cooler and fire goes out but blower continues
- it fires up a second time....air gets warmer....same results....air blows cooler but fan stays on
- it fires up a third time....same thing occurs
- after third attempt the system shuts off
It sounds like it starts up...fires up and then something is causing the fire in the furnace to extinguish
I have have all registers open.
What gives?
  • Sounds like the furnace is thinking the burner has failed to light.
    Typically it will try three times then quit.
    I assume you are plugged in with 12+ volts on the battery.
    I would take it back under warranty. Don't monkey too much or it will be your fault.
  • newman fulltimer wrote:
    your bottles were not properly purged so has alot of air in them furnace is high propane demand.
    so get your bottles repurged bet the oroblem goes away
    Even though it worked 2 months ago when we first took delivery of the rv?
    BUT I have disconnect the main two tanks a few times to install my hitch.
    I will also add that all other gas fed appliances work as well. (oven, outdoor stove, indoor stove & hot water heater/LP)
  • your bottles were not properly purged so has alot of air in them furnace is high propane demand.
