sidney's avatar
sidney
RV LP Furnace Efficiency?
I'm trying to find the actual efficiency rating of our Suburban RV furnace... but so far have found no published specifications.
Anyone have the real world efficiency rating of the typical RV LP furnace... I'm guessing 70 to 75%.
I'm trying to compare the cost of electric heat at 13 cents per kilowatt hour vs LP at $2.79/gallon and assuming 75% efficiency.
Using the link below... LP @ 2.79/gal vs 13 cents per kW hour... its less expensive to heat with electricity.
http://www.maxmcarter.com/fuels/fuelscalc.html
Electric vs Fuels - Comparison Result
Electric:
Electric rate (per kilowatt-hour) = 0.130
Cost of heat (per 100,000 BTU) = 3.81
Fuel:
Propane cost per gallon = 2.79
Burner efficiency factor = 75%
Cost of heat (per 100,000 BTU) = 4.03
  • Gdetrailer wrote:
    As Sidecar mentions, they are not built for efficiency, but neither is most RVs.
    Your in Alaska, I hope you are not planning to live in a RV for the winter..
    You have at the most R3 in the floor and the walls R6 and roof R11 in the center, single pane windows with nice cold aluminum frames..
    You have not much more than a oversized wooden fishing hut on wheels.
    You are going to use twice as much energy whether it is propane or electric than what you think you might.
    Yeah, you ARE going to be cold and broke..
    I would be looking at super insulating before trying to calculate the cheapest heat.
    Nope not in Alaska... we are in Utah right now. ( Our 5th wheel has never been in AK... we store it in the lower 48.)
    I'm cheap and just trying to save a buck.
  • As Sidecar mentions, they are not built for efficiency, but neither is most RVs.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
