hondapro's avatar
hondapro
RV pole barn question
I want to build a rv pole barn to store my rv.
I was going to have a metal carport type built but have decided against that.
I want to have a wooden pole type built.
The contractor I have met with said after 14 foot side walls you need to have blueprints and have a inspection done per code.
With 5th wheels being 13+ feet I would like a little more room (we are planning to move to a 5th wheel)
He suggested going 14 foot side wall and using a sissor truss,for more room in the center.
My building can only be 14 feet wide due to space limits.
Does anyone have any thought on this? and what would be my clearence with this type of truss?
Thanks for the help.
  • You need to be taller! If you want to check roof, if you want to do any maintenance on top.
    We have a standard roll up garage door. You would nedd to have more heightth. Yes, you could try a sliding but may not have enough side room. Best would be a large split bar door.
    Plan on some electrical?
    You should check with building authority. I would also say you want it designed and inspected. I beleive you will want to have insurance on it to protect your RV investment.
  • You will be very close to the needed minimum height. The only way to be sure is to view the blueprints. An overhead door will need some room, so ask about other door types. Also, check with the local code people and get that 14' figure in writing, it may not be true.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
