Working on a camper and I am having a issue with the pump. It will not bring water up from the fresh tank. I though it was a bad pump so I replaced it with a new one. When the pump is on, it will o...
You could have debris in the hose running from the fresh water tank to the pump. Usually the city water supply enters your plumbing after the pump and that is all working. You've replaced the pump. Therefore, it would seem logical the problem is between the pump and the tank. Could a leaf or fabric gotten into the fresh water tank the plugged the freshwater feed? Can you use an air compressor and "blow out" the line from the pump back into the tank? Let us know what you find!!
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
