So what should I do now? It did occur to me that sealing it might seal in moisture, but fixing it seemed like the thing to do, much like fixing any cracked caulking.
I believe that the damage could be covered by insurance since it is likely the result of some sort of impact or whatever.
But what can even be done to fix this? Or what do you do in this situation? I assume that the moisture must be dried out, but I am not putting another hole in the roofing before an adjuster looks at it. But what then? Do you just re-seal it and deal with the roof damage? Do they rip it open and replace the damaged material? Can the damage continue to spread or is it contained once dry?
thanks
Matt
