liquidspaceman
May 29, 2013Explorer
BuckBarker wrote:
All the items you listed will help with handling but NONE will help to smooth out the ride. Like said, tire pressure vs. the load you are carrying is critical. Empty, my 2004 E450 rides terribly if aired to 80 psi. Once full of camping gear and items needed for several days, it rides much better.
Thank you for the info. I will definitely deflate the tires when I get home by 10 psi and see if that smooths things out. Or maybe I'll load up the fresh tank with water and add some junk to the back. I just picked it up and driving it home was an awakening.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
