- AlternExplorerTests have shown that most toilet paper users fold the sheet at least once thereby leaving one clean side after the first swipe. Studies have also shown that users who take the time to unfold or re-fold and re-use as the case may be, to purchase 28% less paper on an annual basis.
This represents a significant savings to the consumer and I encourage all to not only save money but to help save forests and each of us do our part to be good ecologists. - bill_hExplorerIn discussing toilet paper, there are several things to consider:
1. A claim of being “septic safe” or “sewer safe” means very little to an RVer. TP in septic systems has a much longer time to dissolve than in an RV black tank. And, of course, “sewer safe” means it will not clog a sewer system, a consideration of little interest to an RVer, given massive amounts of flush water in a sewer-connected toilet.
2. Many makers or marketers of TP have several different products, often with similar sounding names. Walmart, for example, has two on their site. The most recent (May/2012) Consumer Reports test rated Walmart’s “White Cloud 3 ply soft and thick” at the top of their test chart, but it seems to be missing from their site. It was the only TP in the test rated Excellent for strength. It is totally beyond my comprehension why the WM geniuses would drop a top-rated product. A top rating on CR testing is the Holy Grail of marketing, and these guys kicked it to the curb. ..........“White Cloud soft and thick” rated considerably lower on their testing. “White Cloud Ultra Comfort” is on the WM site but was not tested by Consumer Reports. The CR report also has WM “Great Value Ultra Strong” on their ratings, but it does not appear on the WM site. As a matter of interest, that paper is rated only average in strength. Even when we talk about a main line company like Northern, Scott, Charmin, etc, there are different models with similar names and different placing on the test ratings..
3. House brands change on a regular basis. WM, for example, does not have a TP factory, and subcontracts to have their product made. These contracts, as well as their specifications change regularly, as do shortcuts taken by subcontractors. This is done with no notice to the consumer, and often without the knowledge of WM. In a recent (3/1/13) ARTICLE, WM said they will upgrade the White Cloud toilet paper it sells.
4. When Consumer Reports rates TP on softness, strength and disintegration, there can be a conflict. We all want soft, but softness can take away strength. We all want disintegration, but not while using it. Strength can reduce disintegration.
5. The commonly cited jar test has us shaking the jar to test disintegration. The winner of that test would make me a little wary of it disintegrating before it goes down the drain. If I were water jar testing, I would favor a paper that did not disintegrate right away, but would still disintegrate in my black tank. - RaymonExplorer
nitrohorse wrote:
Raymon wrote:
DaSu wrote:
This thread is starting to go down the toilet.
X2 I cannot believe the moderator has not closed this ridiculous thread. I wish toilet paper for my RV was all that I had to worry about! Sure glad I do not lead such a dull life. JMHO
I read maybe the first 6 postings and then they got boring. Seriously, don't people have more important things to do than worry about Walmart no longer stocking a certain brand of toilet tissue? I know I certainly have more important things to do. However, to each his own I guess.
Ray
Ray
Come on Ray, admit it, you read this and it kept you entertained.
Your life is dull if you're on here complaining about this thread. - bill_hExplorer
docj wrote:
We tested currently available rolls of "Angel Soft" and it definitely does not dissolve as rapidly as it used to.
Thank you for the useful post. - wayward1ExplorerCould be a sticky:D
- Racefan1ExplorerThe sooner the better!!!!
- Mountain_JackExplorerWe use the Sears catalog...:B:B:B
- DaSuExplorerTwo more post and it will. be closed ................;-)
- 2oldmanExplorer II
beemerphile1 wrote:
Sure.. just get permission first.
Is it okay to dump my holding tanks in the parking lot drains at Walmart? - wayward1ExplorerWhen parked long term, I only let the grey tank run free. The black is held (valve closed) and deodorant is used in the tank. When I get a couple days worth I run water from the shower down the toilet to get some water with the "stuff" to help flush it out. If your hooked up with the black tank valve open all the time the liquid out runs the solids and leaves the solid behind. After a couple weeks you have a poop/paper dam that the liquid flows over other wise known as a clog.
Looking for advice before your next adventure? Look no further.25,156 PostsLatest Activity: Aug 13, 2025
