mdoverkamp's avatar
mdoverkamp
RV water hose/spigot issue (winter)
Good afternoon folks. You guys have been super helpful over the last few weeks so hopefully you can help.
We are currently living on out land in the fifth wheel as are building our home.
We have a garden hose hooked to our well and the spigot is outside the the well house. We do have a heat lamp inside the well house but this am when the temps dropped to 18 degrees we had our water freeze.
I’ve done research. Went to Ace and Sutherland’s and can’t seem to get any straight answers on the correct way to do it.
The first thing we found was a heated hose which is fine (and expensive) but that doesn’t help our freezing spigot issue. Then we have the heat tape but they all warn against putting heat tape on hoses.
Should we build a small area around the spigot and put another lamp in that small enclosure? Should we wrap insulation around the entire hose and spigot? Is there anything we need to be concerned about with pipes under the camper (bathroom etc)?
Thank you for any help or guidance.
We are in Missouri so this weather will be prevalent throughout the winter.
Thank you.
  • I used a heat tape on a hose for years without any problem. I ran the tape parallel to the hose (not wrapped) and it worked for years!
  • Build a dog house around the bib.
    Skirt the RV and add an oil filled electric heater near the waste valves.
    Use the on board fresh water tank and fill as needed.
    Have a look at the winter camping thread under the full time forum.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
