TS21sso's avatar
TS21sso
Safety Chains
I have the Blue Ox safety chains, which have hooks on “towed “ end and threaded links on MH end, I assume there is a reason they are made that way. I have considered placing hooks on MH end as well in order to speed up hooking & unhooking. Any views as to why I should or shouldn’t consider this change. I don’t want to compromise safety for speed, but if it doesn’t, then I’ll opt for the time saved.
  • I leave my chains on the mh all the time. I simple wrap the chains around the stowed towbar and cover the entire thing with the cover that came with the towbar.
  • Beverley&Ken wrote:
    Unless you remove the tow bar regularly, just leave the safety cables semi permanently attached to the MH. Just find a point on the rear of the MH that the books can attach to and not drag if you drive the MH without the towed.
    Ken
    x2
  • Unless you remove the tow bar regularly, just leave the safety cables semi permanently attached to the MH. Just find a point on the rear of the MH that the books can attach to and not drag if you drive the MH without the towed.
    Ken
  • i had similar chains but didn't like them for the same reason. instead of modifying them with hooks i just bought a new pair rated for 7500-1bs with snap hooks on both ends.
  • Detaching both ends might be a plan. Store them where?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
