ScottG
Mar 15, 2018Nomad
Glad your wife is OK.
If the 1/2 ton is like the HD trucks, the hitch assembly is actually a cross member. I would check it over very closely for damage. They are designed to rotate upward in a crash. You should be able to put a drawbar in it and see if that has happened at all. I would also inspect welds for cracks.
And yes, have the shop check it very closely too.
Good luck,
Scott
Good luck,
Scott
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 07, 2026
