- Adam_HExplorerI had to add air bags to my EX to overcome the soccer mom springs Ford put in, and I have been very happy with the results. Thought about a spring swap (X code I think) but didn't want any lift/height added to it. Seems to barely fit in a lot of the parking garages in the area with only an inch or 2 to spare.
Adam - APTExplorerMy understanding is the rear springs are fairly soft on the Excursion, and these exact ones are now 13 years old. I'd talk to a suspension shop about just replacing them with some that have a little higher spring rate.
- goducks10ExplorerOP's setup per profile
Ford 2004 Excursion Eddie Bauer 6.0L
3.73 rear axle
137 in wheel base
Hensley Arrow hitch
Prodigy trailer brake
Starcraft/Homestead 29SKS - JIMNLINExplorer IIIGive Helwig a 1-800. They can give you what actually works. We can only guess what works.
- HannibalExplorerThe rear of our F250 settles 1.5" with the hitch properly adjusted. This is normal. How much sag are you seeing?
- 1492Moderator
- camp-n-familyExplorerWhat do you mean by sagging exactly? 1 inch? 5 inches? What is your tongue weight? Is the hitch adjusted correctly?
Some sag is normal. Even with the hitch adjusted you will still have a couple of inches of sag.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
