2112
Jan 04, 2014Explorer II
Screw In Tire
I picked up a wood screw in one of my FW ST tires yesterday. The tires are less than 1 year old and has about 2K miles to date. I took it to the tire shop requesting a plug-patch. The resident tir...
Me Again wrote:FastEagle wrote:
Then you should know that a plug by itself is not going to prevent water intrusion.
FE
As I noted above, I thought it was the other way around? The plug prevents water/moisture from getting to the steel belts vs when only a patch is used. That is why industry standards call for the plug/patch!
Chris
